Sets switching mode characteristics for the selected interface
switchport [access|mode|trunk]
switchport access vlan [<1-4094>|<VLAN-ALIAS-NAME>]
switchport mode [access|trunk]
switchport trunk [allowed|fabric-attach|native]
switchport trunk allowed vlan [<VLAN-ID>|add <VLAN-ID>|none|remove <VLAN-ID>]
swithcport trunk fabric-attach vlan [<1-4094>|<VLAN-ALIAS-NAME>] isid <1-16777214>
switchport trunk native [tagged|vlan [<1-4094>|<VLAN-ALIAS-NAME>]]
| access vlan [<1-4094>| <VLAN-ALIAS-NAME>] | Sets the VLAN
                        when interface is in the access mode. You can either directly specify the
                        native VLAN ID or use a VLAN alias to identify the native VLAN.
 An Ethernet port in the access mode accepts packets only from the native VLAN. Frames are forwarded out the port untagged with no 802.1Q header. All frames received on the port are expected as untagged and are mapped to the native VLAN. |
| mode [access|trunk] | Sets the
                        interface‘s switching mode to access or trunk (can only be used on physical
                        - layer 2 - interfaces)
| trunk allowed | Sets trunking mode, allowed VLANs characteristics of the port. Use this option to add VLANs that exclusively send packets over the listed port. |
| vlan [<VLAN-ID>| add <VLAN-ID>| none| remove <VLAN-ID> | Sets allowed
                        VLAN options. The options are:
 Allowed VLANs are configured only when the switching mode is set to “trunk”. |
switchport trunk fabric-attach vlan [<1-4094>|<VLAN-ALIAS-NAME>] isid <1-16777214>
| trunk | Sets trunking mode characteristics of this Ethernet port |
| fabric-attach | Enables FA (Fabric Attach) client
                        operation on this Ethernet port. Use this option to
                        enable non-SPB WiNG devices (access points and
                        controllers) as FA Clients. The Fabric Attach topology type allows an AP to attach to a SPB (Shortest Path Bridging) (Fabric Connect) Network. The client component on the AP communicates directly with the server on an edge switch (or it can communicate with the server through a proxy) to allow the AP to request VLAN to I-SID (backbone Service Identifier [IEEE 802.1 ah] mappings). FA enabled switches, in the FC network, send out LLDP messages with TLV extensions of Organization-specific TLV with OUI, to discover FA clients and advertise capabilities. Note: When Fabric Attach is
                           configured, LLDP (Link Layer Discovery Protocol) is
                           automatically enabled on all APs associated with the
                           topology. The setting cannot be disabled by
                           users. The switch requires that the VLAN/I-SID mapping is unique per port per switch, therefore only one AP per switch port is allowed. WiNG devices connected to an FA-enabled edge switch auto-learn interface configuration from the edge switch. The WiNG device auto-configures the VLAN on that interface supplied from the edge switch. The edge switch may mark/unmark the VLAN for tagging and this reflects in the interface configuration of the WiNG device. The auto-configuration is local to the AP/controller and does not persist across reboots. It is recommended that you enable “no auto-learn staging-config” on the controller adopting the AP. We also recommend that the controller has the AP‘s interface configuration pre-configured on the AP's profile, to avoid the controller overriding the AP‘s configuration, resulting in the AP losing connectivity with the controller. Use this command to configure the I-SID (Individual Service Identifier) to VLAN mapping that the FA Client uses to negotiate with the FAS. Note: You
                           can configure FA Client capability on a device‘s
                           profile as well as device contexts. Note: This
                           option is enabled only when the switching mode is set
                           to trunk. |
| vlan [<1-4094>|<VLAN-ALIAS-NAME>] | Configures the VLAN through which traffic from
                        this device is routed to the FA switch
 The FA Client requests acceptance of the I-SID to VLAN mapping from the FAS within the FC (Fabric Connect) network. Once acceptance is achieved, the FC edge switch applies the I-SID to the VLAN traffic from the device (AP or controller), and uses this I-SID inside the Fabric. Note: Both the FA Client and FA switch (at the edge of
                           the FC network) use LLDP Element and Assignment Type-Length-Values (TLVs)
                           to advertise their identity and FA capabilities. |
| isid <1-16777214> | Configures the I-SID to be associated with the
                        VLAN interface specified above.
 Note: A maximum of 94 pairs of I-SID to VLAN
                           mappings can be configured per Ethernet port. |
| trunk | Sets trunking mode characteristics of the switchport |
| native [tagged|vlan [<1-4094>| <VLAN-ALIAS-NAME>]] | Configures the
                        native VLAN ID for the trunk-mode port The native VLAN allows an Ethernet device to associate untagged frames to a VLAN when no 802.1Q frame is included in the frame. Additionally, the native VLAN is the VLAN untagged traffic is directed over when using a port in trunk mode.
Interfaces ge1 - ge4 can be configured as trunk or in access mode. An interface configured as “trunk” allows packets (from the given list of VLANs) to be added to the trunk. An interface configured as “access” allows packets only from native VLANs.
Use the [no] switchport (access|mode|trunk) to undo switchport configurations.
nx9500-6C8809(config-profile-testnx5500-if-ge1)#switchport trunk native tagged nx9500-6C8809(config-profile-testnx5500-if-ge1)#switchport access vlan 1 nx9500-6C8809(config-profile-testnx5500-if-ge1)#show context interface ge1 description "This is GigabitEthernet interface for Royal King" speed 10 duplex full switchport mode access switchport access vlan 1 spanning-tree bpduguard enable spanning-tree bpdufilter disable --More-- nx9500-6C8809(config-profile-testnx5500-if-ge1)#
The following is the basic configuration required to enable a device as a FA Client, with tagged native VLAN traffic:
ap8432-070235(config-device-74-67-F7-07-02-35-if-ge1)#switchport mode trunk
ap8432-070235(config-device-74-67-F7-07-02-35-if-ge1)#switchport trunk fabric-attach vlan 1 isid 1
ap8432-070235(config-device-74-67-F7-07-02-35-if-ge1)#switchport trunk fabric-attach vlan 2 isid 200
ap8432-070235(config-device-74-67-F7-07-02-35-if-ge1)#switchport trunk fabric-attach vlan 100 isid 1000
ap8432-070235(config-device-74-67-F7-07-02-35-if-ge1)#switchport trunk allowed vlan 1-2,100
ap8432-070235(config-device-74-67-F7-07-02-35-if-ge1)#switchport trunk native tagged
ap8432-070235(config-device-74-67-F7-07-02-35-if-ge1)#show context interface ge1 switchport mode trunk switchport trunk fabric-attach vlan 1 isid 1 switchport trunk fabric-attach vlan 2 isid 200 switchport trunk fabric-attach vlan 100 isid 1000 switchport trunk native vlan 1 no switchport trunk native tagged switchport trunk allowed vlan 1-2,100 ap8432-070235(config-device-74-67-F7-07-02-35-if-ge1)#
| no | Disables or reverts interface settings to their default |
