permit (ip-snmp acl)
      Creates a permit SNMP MIB object traffic rule. Use this command to
        specify the match criteria based on which SNMP traffic is permitted.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
      permit [<IP/M>|any|host <IP>]
    Parameters
              | permit [<IP/M>|any|host <IP>] | Configures the match criteria for this permit rule
                  <IP/M> – Specifies a network address and mask in the A.B.C.D/M format.
                    Packets received from or destined for this network are forwarded.any – Specifies the match criteria as any. Packets received from or destined
                    for any address are forwarded.host <IP> – Identifies a host by its IP address. Packets received from or
                    destined for this host are forwarded. |
      nx9500-6C8809(config-ip-snmp-acl-test)#permit host 192.168.13.13
      nx9500-6C8809(config-ip-snmp-acl-test)#show context
ip snmp-access-list test
 deny 192.168.13.0/24
