Configures the selected GE port as a member of a port channel group (also referred as LAG)
As per the IEEE 802.3ad standard, LACP enables the aggregation of multiple physical links (ethernet ports) to form a single logical channel. When enabled, LACP dynamically determines if link aggregation is possible and then automatically configures the aggregation. LACP also allows the switch to dynamically reconfigure the LAGs. The LAG is enabled only when LACP detects that the remote device is also using LACP and is able to join the LAG.
Successful aggregation of two or more physical links is feasible only if the aggregating physical links are configured identically. To ensure uniformity in configuration across LAG members, implement configuration changes (such as changes in the switching mode, speed, etc.) on the logical port (the port-channel) and not on the physical port. Changes made on the port-channel will cascade down to each member of the LAG thereby retaining uniformity.lacp-channel-group <1-4> mode [active|passive]
| lacp-channel-group <1-4> | Associates this GE port with an existing
                        port-channel group
 Use the interface > port-channel > <1-4> command to configure a port-channel group. For more information, see interface-config-port-channel-instance. |
| mode [active|passive] | After
                        configuring the selected port as a LAG member, specify whether the port is
                        an active or passive member within the group. An active member initiates and
                        participates in LACP negotiations.
 At least one port within a LAG, on either of the two negotiating peers, should be in the active mode. LACP negotiations are not initiated if all LAG member ports are passive. Further, the peer-to-peer LACP negotiations are always initiated by the peer with the lower system-priority value. For more information on configuring the system-priority, see lacp. |
nx9500-6C8809(config-profile-testnx9000-if-ge1)#lacp-channel-group 2 mode active nx9500-6C8809(config-profile-test2nx9000-if-ge1)#show context interface ge1 lacp-channel-group 2 mode active lacp port-priority 2 nx9500-6C8809(config-profile-test2nx900-if-ge1)#
To enable dynamic link aggregation on a device (service platform), execute the following steps:
nx9500-6C8809(config-device-B4-C7-99-6C-88-09)#interface port-channel 1
Set the switching mode to access or trunk as per requirement. In this example, the mode is set to ‘access‘.
nx9500-6C8809(config-device-B4-C7-99-6C-88-09-if-port-channel1)#switchport mode access
Specify the VLAN to switch, commit changes and exit.
nx9500-6C8809(config-device-B4-C7-99-6C-88-09-if-port-channel1)#switchport access vlan 1 nx9500-6C8809(config-device-B4-C7-99-6C-88-09-if-port-channel1)#commit nx9500-6C8809(config-device-B4-C7-99-6C-88-09-if-port-channel1)#exit
nx9500-6C8809(config-device-B4-C7-99-6C-88-09)#interface ge 2
Enable link aggregation and associate the port with the port-channel group created in step 1.
nx9500-6C8809(config-device-B4-C7-99-6C-88-09-if-ge2)#lacp-channel-group 1 mode active Note, the mode can be set to passive. However, at least one of the aggregated GE ports in the port-channel group should be active in order to initiate link aggregation negotiations with other LACP-enabled peers.
Specify the GE port‘s priority value.
nx9500-6C8809(config-device-B4-C7-99-6C-88-09-if-ge2)#lacp port-priority 2
| no | Removes the selected GE port‘s port-channel group membership |
