default-information
      Controls the distribution of default
         route information. Use the  command to advertise a default route in the routing table.This option is
            disabled by default. When enabled, the default route becomes a distributed
         route.
            - Access Points — AP410i/e, AP460i/e,
               AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562, AP7612, AP7632, AP7662, AP8432,
               AP8533
Syntax
         default-information originate {always|metric|metric-type}
         default-information originate {always|metric <0-16777214>|metric-type [1|2]}
{(metric <0-16777214>|metric-type [1|2])}
      Parameters
                     | originate | Originates default route information. Enabling this feature makes the
                        default route a distributed route. This option is disabled by
                        default. |
                     | always | Optional. Always distributes default route information (will continue to
                        advertise default route information even if that information has been
                        removed from the routing table for some reason). This option is disabled by
                        default. |
                     | metric <0-16777214> | This is a recursive parameter and can be optionally configured along
                        with the metric-type option.
                           metric
                              <0-16777214> – Optional. Specifies OSPF metric value for
                              redistributed routes (this value is used to generate the default
                                 route)
                                 <0-16777214> – Specify a value from 0 - 16777214. |
                     | metric-type [1|2] | This is a recursive parameter and can be optionally configured along
                        with the metric option.
                           metric-type [1|2] –
                              Optional. Sets OSPF exterior metric type for redistributed routes
                              (this information is advertised with the OSPF routing domain)
                                 1 – Sets OSPF
                                    external type 1 metrics2 – Sets OSPF
                                    external type 2 metrics |
         nx9500-6C8809(config-profile default-ap8533-router-ospf)#default-information
originate metric-type 2 metric 1
         nx9500-6C8809(config-profile default-ap8533-router-ospf)#show context
 router ospf
  area 0.0.0.4
  auto-cost reference-bandwidth 1
  default-information originate metric 1 metric-type 2
