crypto-map-ipsec-isakmp-instance
Configures the IKEv1 or IKEv2 peer for the auto site-to-site VPN tunnel or remote VPN client. The peer device can be specified either by its hostname or by its IP address. A maximum of three peers can be configured.
peer <1-3> [ikev1|ikev2] <IKEv1/IKEv2-PEER-NAME>
| peer <1-3> | Creates a new peer and configures the peer‘s priority level. Peer ‘1‘ is the primary peer, and peer ‘3‘ is redundant. |
| ikev1 <IKEv1-PEER-NAME> | Configures an
                        IKEv1 peer
| ikev2<IKEv2-PEER-NAME> | Configures an
                        IKEv2 peer
Site-to-site tunnel: nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#1)#peer 1 ikev2 ikev2Peer1 nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#1)#show context crypto map test 1 ipsec-isakmp peer 1 ikev2 ikev2Peer1 local-endpoint-ip 192.168.13.10 ip nat crypto nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#1)# Remote VPN client: nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#2)#peer 1 ikev1 RemoteIKEv1Peer1 nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#2)#show context crypto map test 2 ipsec-isakmp dynamic peer 1 ikev1 RemoteIKEv1Peer1 local-endpoint-ip 157.235.204.62 nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#2)#
