This preface provides an overview of this guide and a brief summary of each chapter, defines the conventions used in this document; and instructs how to obtain technical support from Extreme Networks.
To locate information about various subjects in this guide, refer to the following table.
| For... | Refer to... |
| An overview of the product, its features and functionality. | Overview of the ExtremeWireless Solution |
| Information about how to perform the installation, first time setup and configuration of the controller, as well as configuring the data ports and defining routing. | Configuring the ExtremeWireless Appliance |
| Information on how to install the ExtremeWireless AP, how it discovers and registers with the controller, and how to view and modify radio configuration. | Configuring the ExtremeWireless APs |
| An overview of topologies and provides detailed information about how to configure them. | Configuring Topologies |
| An overview of roles and provides detailed information about how to configure them. | Configuring Roles |
| An overview of WLAN (Wireless Local Area Network) services and provides detailed information about how to configure them. | Configuring WLAN Services |
| An overview of Virtual Network Services (VNS), provides detailed instructions in how to configure a VNS, either using the Wizards or by manually creating the component parts of a VNS. | Configuring a VNS |
| Information about configuring CoS (Class of Service) which are a configuration entity containing QoS Marking (802.1p and ToS/DSCP), Inbound/Outbound Rate Limiting and Transmit Queue Assignments. | Configuring Classes of Service |
| Information about configuring Sites which is a mechanism for grouping APs and refers to specific Roles, Classes of Service (CoS) and RADIUS servers that are grouped to form a single configuration. | Configuring Sites |
| An overview of Mesh networks and provides detailed information about how to create a Mesh network. | Working with a Mesh Network |
| An overview of a Wireless Distribution System (WDS) network configuration and provides detailed information about how to create a Mesh network. | Working with a Wireless Distribution System |
| Information on how to set up the features that maintain service availability in the event of a controller failover. | Availability and Session Availability |
| Information on how to set up the mobility domain that provides mobility for a wireless device user when the user roams from one ExtremeWireless AP to another in the mobility domain. | Configuring Mobility |
| Information on how to use the ExtremeWireless AP features with third-party wireless access points. | Working with Third-party APs |
| Information on the security tool that scans for, detects, provides countermeasures, and reports on rogue APs. | Working with ExtremeWireless Radar |
| Information on the various reports and displays available in the system. | Working with Reports and Statistics |
| Information on system administration activities, such as performing ExtremeWireless AP client management, defining management users, configuring the network time, and configuring Web session timeouts. | Performing System Administration |
| Information on how to view and interpret the logs, traces, audits and DHCP (Dynamic Host Configuration Protocol) messages. | Logs, Traces, Audits and DHCP Messages |
| Information on how to configure GuestPortal accounts. | Working with GuestPortal Administration |
| A list of terms and definitions for the ExtremeWireless Appliance and the ExtremeWireless AP as well as standard industry terms used in this guide. | Glossary terms are displayed as links in the text. Hover over a glossary term to display the definition, or click the link to go to the Glossary. |
| Regulatory information for the ExtremeWireless Appliances and the ExtremeWireless APs. | Regulatory Information |
| The default GuestPortal ticket page source code. | Default GuestPortal Ticket Page |
