Creating a Voice VNS Using the VNS Wizard
Use the VNS wizard to create a voice-specific VNS that can support various wireless telephones, including optiPoint, Spectralink, Vocera, and Mobile Connect - Nokia.
When you use the VNS wizard to create a voice-specific VNS, you optimize the voice VNS to support one wireless telephone vendor. If the voice VNS needs to be optimized for more than one wireless phone vendor, use the advanced method to create the voice-specific VNS. For more information, see Enabling and Disabling a VNS.
When you create a new voice VNS using the VNS wizard, you configure the VNS in the following stages:
To configure a Voice VNS using the VNS Wizard:
  1. From the top menu, click VNS. The Virtual Network Configuration screen displays.
  2. In the left pane, expand the New pane, then click START VNS WIZARD. The VNS Creation Wizard screen displays.
    Graphics/VNS_creation_wizard_screen.jpg
  3. In the Name box, type a name for the voice VNS.
  4. In the Category drop-down list, click Voice.
  5. Click Next. The Basic Settings screen displays.
