Radius Configuration
A single Site definition can be configured with one or two RADIUS servers. The RADIUS servers assigned to a Site can only be selected from the list of servers displayed on the RADIUS Configuration dialog.
To select site RADIUS servers:
  1. From the Configuration tab, under RADIUS Server used, click Configure. The RADIUS Configuration dialog displays.
    Graphics/Sites_Radius_config.jpg
  2. Select a RADIUS server from the list of available servers and click the right-arrow button.
    The server will be moved under the RADIUS Servers used list.
  3. Click the Move Up or Move Down buttons to change the order of the RADIUS Servers used.
  4. Click the Advanced button. The RADIUS Advanced Configuration dialog appears.
    Graphics/Sites_Radius_config_advanced.jpg
  5. The following values can be edited:
    • NAS IP Address — Click the checkbox to use the existing IP address of the VNS server, or enter an alternate IP Address in the box provided.
    • NAS Identifier — Click the checkbox to use the name of the existing VNS server, or enter an alternate name in the box provided.
    • Auth. type — Select an authorization protocol from the drop-down list (PAP, CHAP, MS-CHAP, or MS-CHAP2).
    • Password — To override the default password (see VNS Global Settings) for MBA - MAC Based authorization only. Select Mask to display the password, and select Unmask to hide the entry.
  6. Click Close.
