Using the Captive Portal Editor
The Captive Portal Editor enables you to configure the look and feel of a captive portal page.
To configure the editor:
  1. From the top menu, click VNS.
  2. In the left pane expand WLAN Services, then select the WLAN (Wireless Local Area Network) Service. The WLAN Services configuration page displays.
  3. Click the Auth & Acct tab. The Auth & Accounting page displays.
  4. In the Authentication Mode drop-down list, select a Captive Portal option.
  5. Click Configure. The Captive Portal Configuration page displays.
  6. In the Communications Options section, select Manual Settings and then click Launch Captive Portal Editor. For more information, see. Captive Portal Editor - Fields and Buttons.
The Captive Portal Editor page supports only one administrator editing a captive portal page at one time.
Graphics/captive_portal_editort.jpg
Caution
Caution
In order for Captive Portal authentication to be successful, all the URLs referenced in the Captive Portal setup must also be specifically identified and allowed in the non-authenticated filter. For more information, see Policy Rules.
Caution
Caution
If you use logos or graphics, ensure that the graphics or logos are appropriately sized. Large graphics or logos may force the login section out of view.
