Modifying the Default Setting of Wireless
APs Using the Copy to Defaults Feature
The Copy to Defaults feature allows the
properties of an already configured AP to become the system‘s default AP settings.
To modify the system default
AP settings based on an already configured AP:
From the main menu, click
AP and select the AP whose
properties you want to use as the default. You can modify the properties here if
necessary.
Click Copy to Defaults and click OK to confirm your
changes.
