Blacklisted Clients
The Blacklisted Clients report lists all devices that are currently on the blacklist (or removed from the whitelist if the list is in whitelist mode) because of the application of countermeasures to an attack. Clients automatically added to the Blacklist will be removed automatically after the interval configured passes. Station addresses manually added to the Blacklist (or manually removed from the Whitelist) do not appear in this report.
Viewing Blacklisted Clients Scan Results
  1. From the top menu, click Reports.
  2. In the left pane, click Radar.
  3. Click Blacklisted Clients. The Blacklisted Clients Report screen displays.
    Graphics/blacklisted_clients.jpg
Blacklisted Clients Report - Fields and Buttons
Field/Button Description
Blacklisted Address MAC address of the blacklisted device.
Blacklisting Started at Date and time when the device was added to the blacklist.
Blacklisting Ends at Date and time when the device was removed from the blacklist.
Reason Reason for blacklisting the device.
To modify the page‘s refresh rate:
  1. Type a time (in seconds) in the Refresh every __ seconds box at the top of the screen and click Apply. The new refresh rate is applied.
  2. To refresh the page, click Refresh.
  3. To export a copy of the report in XML format, click Export.
  4. To close the report window, click Close.
