Configuring the RADIUS, Local Login Authentication Mode
To configure the RADIUS, Local login authentication mode:
  1. From the top menu, click Controller.
  2. In the left pane, click Administration > Login Management. The Login Management screen displays.
    Graphics/authentication_default.jpg
  3. In the Authentication mode section, click Configure.
    The Login Authentication Mode Configuration window is displayed.
    Graphics/authentication_local.png
  4. Select the Local and RADIUS checkbox.
    Graphics/auth_local_radius.png
  5. If necessary, select RADIUS and use the Move Up button to move RADIUS to the top of the list.
    Graphics/auth_radius_move_up.png
  6. Click OK.
  7. On the Login Management screen, click Save.
For information on setting RADIUS login authentication settings, see Configuring the RADIUS Login Authentication Mode.
For information on setting local login authentication settings, see Configuring the Local Login Authentication Mode and Adding New Users.
