Creating a Firewall Friendly External Captive Portal VNS - Filtering Screen
The Filtering screen displays:
Graphics/VNS_creation_wizard_FF_Ext_CP_filtering.jpg
  1. In the Filter ID drop-down list, click one of the following:
    • Default — Controls access if there is no matching filter ID for a user.
    • Exception — Protects access to the controller‘s own interfaces, including the VNSs own interface. VNS exception filters are applied to user traffic intended for the controller's own interface point on the VNS. These filters are applied after the user's specific VNS state assigned filters.
    • Non-Authenticated — Controls network access and also used to direct mobile users to a Captive Portal Web page for login.
  2. In the Filter table, select the Allow or Deny option buttons for each filter if applicable, and then select the Enable checkbox accordingly.
  3. Click Next. The Privacy screen displays.
