If you change any of the following configuration parameters of a WDS AP, the WDS AP will reject the change: Reassigning the WDS AP‘s role from Child to None, Reassigning the WDS AP‘s role from Both to Parent, and changing the Preferred Parent of the WDS AP. However , the wireless controller will display your changes, as these changes will be saved in the database. To enable the WDS AP to obtain your changes, you must remove it from the WDS location and then connect it to the wireless Controller via the wired network.Note
If you change any of the following radio properties of a WDS AP, the WDS AP will reject the change: Disabling the radio on which the WDS link is established, lowereing the radio‘s Tx Power of a radio on which the WDS link is established, or changing the country
