Setting the Primary or Secondary Wireless
Controllers for Availability
To Set the Primary or Secondary Controllers for Availability:
From the top menu, click
Controller. The Wireless Controller
Configuration screen displays.
In the left pane, click .
To enable availability, select the Paired option.
Do one of the following:
- For a primary controller, in the Wireless IP Address box, type the IP address of the data interface of the secondary controller. This IP address must be on a routable subnet between the two controllers.
- For a secondary controller, in the Wireless IP Address box, type the IP address of the Management port or data interface of the primary controller.
Set this controller as the primary or secondary connection point:
- To set this controller as the primary connection
point, select the Current Wireless is primary connect point
checkbox.
- To set this controller as the secondary connection
point, clear the Current Wireless is primary connect point
checkbox.
If the Current Wireless is primary connect point
checkbox is selected, the specified controller sends a connection request. If
the Current Wireless is primary connect point checkbox
is cleared, the specified controller waits for a connection request. Confirm
that one controller has this checkbox selected, and the second controller has
this checkbox cleared, since improper configuration of this option will result
in incorrect network configuration.
On both the primary and secondary controllers, type the Detect link failure value.
Ensure that the Detect link failure value on both the controllers is identical.
On both the primary and secondary controllers, select the Synchronize GuestPortal Guest Users option to synchronize GuestPortal guest accounts between the controllers.
AP.
In the left pane, click . To set the security mode for the controller, select one of the following options:
- Allow all wireless APs to
connect — If the controller does not recognize the serial number,
it sends a default configuration to the AP. Or, if the controller recognizes the
serial number, it sends the specific configuration (port and binding key) set for
that AP.
- Allow only approved wireless APs to
the APs will be in pending mode and the administrator must manually approve them.
Or, if the controller recognizes the serial number, it sends the configuration for
that AP.
During the initial setup of the network, it is recommended
that you select the
Allow all Wireless APs to connect
option. This option is the most efficient way to get a large number of APs
registered with the controller. Once the initial setup is complete, it is
recommended that you reset the security mode to the
Allow only approved
Wireless APs to connect option. This option ensures that no
unapproved APs are allowed to connect. For more information, see
Configuring Wireless AP Properties.
To save your changes, click
Save.
When two controllers have been paired as
described above, each controller's registered APs will appear as foreign on the
other controller in the list of available APs when configuring a VNS
topology.
Verify that availability is configured correctly.
