Configuring the Default Wireless AP Settings
Wireless APs are added with default settings. You can modify the system‘s AP default settings, and then use these default settings to configure newly added APs. In addition, you can base the AP default settings on an existing AP configuration or you can make pre-configured APs inherit the properties of the default AP configuration when they register with the system.
Each AP model has its own tab:
