To help administrators manage large numbers of guest accounts, you can import and export .csv (comma separated value) guest files for the controller.
The following describes the column values of the .csv guest file.
Guest Account Import and Export .csv File Values
Column | Value |
A | User ID |
B | User name |
C | Password |
D | Description |
E | Account activation date |
F | Account lifetime, measured in days |
G | Session lifetime, measured in hours |
H | Is the account enabled (1) or disabled (0) |
I | Time of day, start time |
J | Time of day, duration |
K | Total session used time, measured in seconds. A user session starts when the guest user is authenticated, and ends when the guest user is disassociated. |
L | Is the guest user account synchronized on a secondary controller in an availability pair, yes (1) no (0) |
In the left pane, expand the WLAN Services pane, click the dedicated WLAN (Wireless Local Area Network) Service that provides the temporary guest network services. The WLAN Services configuration window for that service displays.
