The AP3935 and AP3965 provide 5 LED indicators. The LEDs provide status information on the current state of the AP.
LED Indications AP3935 and AP3965
LED | Status | Description |
1 (AP status) | On Green | Indicates that the AP is working normally. |
Flashing Green | Indicates:
On Amber | Indicates a CPU/system failure. | |
2 (Ethernet link state) LAN 1 | On Green | Indicates a valid 100Mbps Ethernet link. |
On Amber | Indicates a valid 1Gbps Ethernet link. | |
Off | Indicates the link is down. | |
3 (Ethernet link state) LAN 2 | On Green | Indicates a valid 100Mbps Ethernet link. |
4 (Radio 1 (5 GHz) status) | On Green | Indicates Radio 1 is enabled. |
Off | Indicates Radio 1 is not on. | |
5 (Radio 2 (2.4 GHz) status) | On Green | Indicates Radio 2 is enabled. |
Off | Indicates Radio 2 is not on. |
