Creating an Internal Captive Portal VNS
To configure an Internal Captive Portal VNS using the VNS Wizard:
  1. From the top menu, click VNS. The Virtual Network Configuration screen displays.
  2. In the left pane, expand the New pane, then click START VNS WIZARD. The VNS Creation Wizard screen displays.
    Graphics/VNS_creation_wizard_screen.jpg
  3. In the Name box, type a name for the Captive Portal VNS.
  4. In the Category drop-down list, click Captive Portal.
  5. Click Next. The Basic Settings screen displays.
