Creating a Data VNS Using the VNS Wizard
Use the VNS wizard to create a data-specific VNS that can be configured to use either SSID or AAA authentication.
When you create a new data VNS using the VNS wizard, you configure the VNS in the following stages:
To configure a data VNS using the VNS wizard:
  1. From the top menu, click VNS. The Virtual Network Configuration screen displays.
  2. In the left pane, expand the New pane, then click START VNS WIZARD. The VNS Creation Wizard screen displays.
    Graphics/VNS_creation_wizard_screen.jpg
  3. In the Name box, type a name for the data VNS.
  4. In the Category drop-down list, click Data.
  5. Click Next. The Basic Settings screen displays.
