The VNS wizard displays the appropriate configuration screens, depending on your selection of the Enable Authentication and Enable DHCP check boxes.
Field/Button | Description |
Radius Server | Click the RADIUS server you want to assign to the new Captive Portal VNS, or click Add New Server and then do the following |
Server Alias | Type a name you want to assign to the new RADIUS server. |
Hostname/IP | Type either the RADIUS server‘s FQDN (fully qualified domain name) or IP address. |
Shared Secret | Type the password that will be used to validate the connection between the controller and the RADIUS server. |
Mask/Unmask | Click to display or hide your shared secret key. |
Roles | Select the authentication role options for
the RADIUS server:
Click Next. The DHCP screen displays.
