Managing Redirection URLs
Configure a list of redirection URLs from the Redirection URL dialog. You can add and delete a URL.
To display the Redirection URL option, enable Rule-based Redirection under Filtering Mode.
For more information, see Configuring the In/Out Rules for WLAN Services Settings.
The URL list can contain up to 255 proper URLs, consisting of Fully-Qualified Domain Name (FQDN) addresses and IPV4 addresses. Duplicate entries are not permitted, and you must ensure that network traffic is accessible to the required IP addresses. The name of the WLAN Service that these entries are created for is displayed on the user interface and on the command line interface. SNMP also displays the URLs when queried through the Policy Profile MIB.
External Captive Portal URLs are not required, but when they exist, they are automatically added to the list.
You cannot configure Captive Portal Redirection using IPv6 classifiers. While you can http to IPv6 websites, you cannot apply Captive Portal redirection to http [s] over IPv6 .
For URL specifications, see Adding a Redirection URL.
