Uploading an Existing Floor File
The Upload Selected button is enabled when a row within the list of floor plans is highlighted.
  1. From the top menu, click Radar.
  2. In the left pane, click Location Engine. The Location Engine Settings screen displays.
  3. Click Advanced. The Advanced dialog displays.
    Graphics/Location_engine_advanced_dialog.jpg
  4. Select a floor file from the list of floor files.
  5. Click Upload Selected. The Upload Floor Plan File dialog displays.
    Graphics/upload_selected_floor_file.jpg
    Upload Floor Plan File Dialog - Fields and Buttons
    Field/Button Description
    Protocol Select the transfer protocol from one of the following:
    • FTP
    • SCP
    Server IP address of the server where the file will be exported.
    User ID Required ID to access the server.
    Password Password required for access to the server.
    Confirm Enter the password for confirmation
    Directory Location of the floor file directory on the destination server.
    Filename File name of the floor plan file on the destination server.
  6. Click Upload to export the floor plan, or click Close to cancel the export.
