A CDR file contains a sequence of CDR records. The file is a standard ASCII text file. Records are separated by a sequence of dashes followed by a line break. The individual fields of a record are reported one per line, in "field=value" format.
The following table describes the records that are displayed in a CDR file.
Most of the CDR records are typical RADIUS server attributes. For more information, refer to the user manual of your RADIUS server.CDR Records and Their Description
CDR Records | Description |
Acct-Session-ID | A unique CDR ID |
User-Name | The name of the user, who was authenticated. |
Filter-ID | The name of the filter list for the user. |
Acct-Interim-Interval | The number of seconds between interim accounting updates. |
Session-Timeout | The maximum number of seconds of service to be provided to the user before termination of the session. |
Class | This field is copied from the access-accept message sent by the RADIUS server during authentication. |
Acct-Status-Type | Indicates whether this Accounting-Request marks the beginning of the user service (Start) or the end (Stop). |
Acct-Delay-Time | Indicates how many seconds the client tried to authenticate send this record for, and can be subtracted from the time of arrival on the server to find the approximate time of the event generating this Accounting-Request. |
Acct-Authentic | Indicates how the user was authenticated, whether by RADIUS (AAA), Local (Internal CP) or Remote (External CP). The field displays one of the following values:
Framed-IP-Address | Indicates the address to be configured for the user |
Connect-Info | This field is sent from the NAS to indicate the nature of the users‘ connection — 802.11b for Radio b/g or 802.11a for radio a. |
NAS-Port-Type | Indicates RADIUS NAS Port Type is Wireless 802.11 |
Called-Station-ID | The Wireless AP‘s MAC address. |
Calling-Station-ID | The client‘s MAC address. |
Extreme Networks-AP-Serial | The AP‘s serial number. |
Extreme Networks-AP-Name | The AP‘s name. |
Extreme Networks-VNS-Name | The VNS name on which the session took place. |
Extreme Networks-SSID | The SSID name on which the session took place. |
Acct-Session-Time | The number of seconds the user has received the service. |
Acct-Output-Packets | The number of packets that were sent to the port in the course of delivering this service to a framed user. |
Acct-Input-Packets | The number of packets that have been received from the port over the course of this service being provided to a Framed User. |
Acct-Output-Octets | The number of octets that were sent to the port in the course of delivering the service. |
Acct-Input-Octets | The number of octets that were received from the port over the course of the service. |
Acct-Terminate-Cause | Indicates how the session was terminated. The field displays one of the following values:
Authenticated_time | Indicates the time at which the client was authenticated. The time is in the following format: Date hh:mm:ss. For example, April 21 2008 14:50:24 |
Disassociation_time | Indicates the time at which the client was disassociated from the AP. The time is in the following format: Date hh:mm:ss. For example, April 21 2008 14:57:20. |
