Defining RADIUS Settings for Individual RADIUS Servers
To Define RADIUS Settings for Individual RADIUS Servers:
From the top menu, click
VNS.
In the left pane expand the
WLAN Services pane, then click
the WLAN (Wireless Local Area Network) Service. The WLAN Services
configuration page is displayed.
Click the Auth & Acct tab.
In the Server table, click the RADIUS server you want to define, and then click Configure. The RADIUS Parameters dialog is displayed.
For NAS IP Address, accept the default of “Use VNS IP address” or de-select the checkbox and type the IP address of a Network Access Server (NAS).
For NAS Identifier, accept the default of “Use VNS name” or type the Network Access Server (NAS) identifier. The NAS identifier is a RADIUS attribute that identifies the server responsible for passing information to designated RADIUS servers and then acting on the response returned.
For Auth. type, select the Protocol using the drop down list. Choices are PAP, CHAP, MS-CHAP, or MS-CHAP2.
In the Password box, type the password that will be used to validate the
connection between the controller and the RADIUS server.
To proofread your shared
secret key, click Unmask. The password is displayed.
Click OK.
To save your changes, click Save.
