The following is a high-level overview of how to view CDRs:
You cannot access the CDR files directly from the CDR directory.When you back up CDRs, both the .work and .dat files are zipped into a single .zip file. This .zip file is uploaded on the remote server. You can unzip this file from the remote server to extract the .work and .dat files.
You can back up and upload the files on the remote server either via the Wireless Assistant (GUI) or CLI.
This section describes how to back up and copy the CDR files to a remote server via the Wireless Assistant (GUI). For more information on how to copy the CDR file to the remote server via CLI, refer to the Extreme Networks ExtremeWireless CLI Reference Guide.
Print
this page
Email this topic
Feedback
