Configuring the In/Out Rules for WLAN Services Settings
To configure the Egress
Filtering Mode:
- From the top menu, click
VNS. The Virtual Network Configuration screen displays.
In the left pane, click
Global > Filtering Mode. The Egress Filtering Mode
Select an egress filtering
mode:
- All
WLAN Services enforce explicitly defined “Out” rules – All
WLAN (Wireless Local Area Network) services enforce outbound filters on egress
traffic exactly as they are defined in the role.
- All
WLAN Services apply “In” policy rules to “Out” direction traffic –
All WLAN services enforce that outbound policy rules that are explicitly defined
in the role are overridden by a set of rules created by copying each inbound role
rule and swapping the source and destination address roles in the rule.
- Use
WLAN Service setting – Each role‘s rules are interpreted in
accordance with the Egress Filtering
Mode setting of each WLAN Service on which the role is applied. In
this mode, it is possible that a role‘s rules can be interpreted in two different
ways at the same time, if it is used simultaneously on a WLAN service that has
Enforce explicitly defined “Out”
rules enabled and on a WLAN service that has Apply “In” rules to “Out” direction
traffic at the same time.
![Note](../../images/Note_Note.png)
The
Use
WLAN Service setting is recommended. If you are using Policy
Manager, configure each WLAN Service‘s Egress filtering option directly from
Policy Manager. Enabling Egress Filtering on a WLAN Service port in Policy
Manager is equivalent to setting
Apply “In” rules to “Out” direction traffic in the
WLAN Service‘s Advanced
dialog.
Select Rule-based Redirection to enable redirection based on configured
policy rules after a packet is denied. For more information, see Rule-Based Redirection.
Upgrade considerations for default Rule-based
Redirection setting:
- This setting is enabled for the following installation
scenarios:
- For new installations of ExtremeWireless v10.11 or
later
- When upgrading from ExtremeWireless v10.11 or
later
- For factory resets of ExtremeWireless v10.11 or
later
- When upgrading from a previous version of ExtremeWireless, this checkbox
is cleared, and Rule-based Redirection is disabled.
