This architecture allows a single controller to control many APs, making the administration and management of large networks much easier.
There can be several controllers in the network, each with a set of registered APs. The controllers can also act as backups to each other, providing stable network availability.
In addition to the controllers and APs, the solution requires three other components, all of which are standard for enterprise and service provider networks:
As illustrated in the above figure, the ExtremeWireless Appliance appears to the existing network as if it were an access point, but in fact one controller controls many APs. The controller has built-in capabilities to recognize and manage the APs. The controller:
Simplifying the APs makes them cost-effective, easy to manage, and easy to deploy. Putting control on an intelligent centralized controller enables:
The ExtremeWireless system:
In turn, each wireless AP can handle a mixture of secure and non-secure clients. AP per radio support is up to 200 clients, of which 127 are clients with security. With additional controllers, the number of wireless devices the solution can support can reach into the thousands.
Plug-in applications include:
