Backing Up and Copying CDR Files to a Remote Server
To Back Up and Copy the CDR Files to a Remote Server:
From the top menu, click
Controller.
In the left pane, click
Click the Backup tab.
From the Select what to backup drop-down menu, click CDRs only, and then click Backup Now. The following window displays the backup status.
To close the window, click Close. The backed up file is displayed in the Available Backups box.
The
.work and
.dat files are zipped
into a single file.
To upload a backup to a Remote, in the section, select Remote, then do the following:
- Protocol — Select the file
transfer protocol you want to use to upload the backup file, SCP or FTP.
- Server — Type the IP
address of the server where the backup will be stored.
The Server Address
field supports both IPv4 and IPv6 addresses.
- User ID — Type the user ID
to log in to the server.
- Password — The password to
- Confirm — The password to
confirm the password.
- Directory — The directory
in which you want to upload the CDR file.
- Filename — Select the
zipped CDR file name.
To upload a backup to Flash, in the section, select Flash, then do the following:
In the Copy
Selected Backup to section, click Copy. The
.zip file is uploaded on to the server.
Unzip the file. The two CDR files — .work and .dat — are visible on the server.
To view CDRs, download the files.
