Deleting 802.1x Credentials
Caution
Caution
Exercise caution when deleting 802.1x credentials. For example, deleting 802.1x credentials may prevent the AP from being authenticated or cause it to lose its connection with the controller.
To delete current 802.1x credentials:
  1. From the top menu, click AP.
  2. In the AP list, click the wireless AP (not the checkbox) for which you want to view its current 802.1x credentials.
  3. Select the 802.1x tab.
  4. Do the following:
    • To delete EAP-TLS credentials, click Delete EAP-TLS credentials.
    • To delete PEAP credentials, click Delete PEAP credentials.
      The credentials are deleted and the AP settings are updated.
      If you attempt to delete the 802.1x credentials of a wireless AP that currently does not have an active session with the controller, the credentials are deleted only after the AP connects with the controller.
