Scheduling a Maintenance Cycle for Specific APs
To schedule a maintenance cycle for specific APs
  1. Go to AP.
  2. In the left pane, click Global Settings > Maintenance.
  3. Click the AP Maintenance Cycle tab.
    The following screen appears:
    Graphics/ap_maint_cycle_tab.png
  4. Click the Start At box to display the Choose Time dialog.
  5. Adjust the sliders for both Hour and Minute to set the time for the AP maintenance cycle, then click Done.
  6. In the Duration drop-down, select the desired duration time (in hours).
  7. Under Recurrence, select the desired frequency.
  8. Under Platforms, select the AP(s) that are included in the maintenance cycle.
  9. Click Save.
