Viewing Software Upgrade Messages
The S/W Upgrade tab displays the most recent upgrade actions, either success or failure, and the operating system patch history. Some examples of the upgrade actions that can be displayed are:
  • FTP failure during backup of system image
  • Configuration reset failure
  • Configuration export failure
  • Configuration import details
To view software upgrade messages:
  1. From the top menu, click Logs. The Logs & Traces screen displays.
  2. Click the S/W Upgrade tab. The software upgrade message screen displays.
    Graphics/sw_upgrade.png
  3. Do the following:
    • To view software upgrade messages, click Detail.
    • To view the operating system history, click History.
  4. To refresh the screen, click Refresh.
  5. To export the software upgrade messages or operating system history, click Export. The File Download dialog is displayed.
  6. Do one of the following:
    • To open the file, click Open.
    • To save the file, click Save, and then navigate to the directory location you want to save the file. Click Save.
