Creating a Data VNS Using the VNS Wizard - Filtering Screen
The Filtering screen displays:
Graphics/VNS_creation_wizard_data_filtering.jpg
  1. In the Filter ID drop-down list, click one of the following:
    • Default — Controls access if there is no matching filter ID for a user.
    • Exception — Protects access to the controller‘s own interfaces, including the VNSs own interface. VNS exception filters are applied to user traffic intended for the controller's own interface point on the VNS. These filters are applied after the user's specific VNS state assigned filters
  2. In the Filter table, select the Allow or Deny option buttons for each filter if applicable, and then select the Enable checkbox accordingly.
  3. Click Next. The Prviacy screen displays.
