Understanding the Message Configuration Page
Message Configuration Page - Fields and Buttons
Field/Button Description
Invalid Enter a message indicating that the user entered an invalid username or password combination.
Success Enter a message to indicate when a user successfully logs in.
Access Fail Enter an error message that indicates the a user login was unsuccessful.
Fail Enter a message indicating an internal error.
Timeout Enter an error message indicating that the user authentication timed out.
RADIUS shared secret security key fail Enter an error message indicating that RADIUS shared secret failed.
RADIUS internal error Enter an error message indicating an internal RADIUS client error
Max RADIUS login fail Enter a message that indicates that the maximum number of simultaneous captive portal logins have been reached.
Invalid Login parameters Enter a message indicating that the user entered an invalid username or password combination.
General failure Enter a message indicating that a general failure has occurred.
Invalid third party parameters Enter an error message indicating that one or more parameters passed from the external captive portal server to the controller is either invalid or missing.
Authentication in progress fail Enter a message indicating that the user credentials were not authenticated.
Topology Change Enter an error message indicating that the topology failed.
Close Click to save your changes and close this page.
Cancel Click to discard your configuration changes and close this page.
