The ExtremeWireless AP3765i, W786C, AP3765e, and AP3767e models are nearly identical in appearance (e models have external antenna ports). LED status indicator displays are the same on all three models. The frontal view of the housing cover (see the following figure) displays six LEDs. These LEDs provide information on operating status.
AP3765/AP3767 LED Status Indicators
LED | Color | Meaning |
L1 | Green | Power LED. When on, indicates AP power is sourced from power supply. |
PoE (Power over Ethernet) | Green | PoE power LED. When on, indicates AP power is sourced from PoE. |
P1 | Green | Ethernet port 1 LED. When green on, indicates Ethernet port activity. When off, Ethernet is off, WDS is enabled. |
R1 | Green | WLAN (Wireless Local Area Network) Radio 1 LED. When green on, indicates Radio 1 is active. |
R2 | Green | WLAN Radio 2 LED When green on, indicates Radio 2 is active. |
F | Red | Error LED. When on, indicates error. When off, indicates normal operation, AP connected to controller. |
