Configuring Guest Password Patterns
This feature makes it easier for system administrators to
create password patterns that the Wireless Assistant will use to auto generate guest passwords.
You can specify a predefined pattern or you can create a customized pattern. You must have full
administrative rights to generate password patterns. Select from the following password patterns:
- Completely Random Sequence
- Two Words
- Phone number
- Postal Code
- Custom Pattern
The generator offers three character sets: Latin (ASCII), Cyrillic, and Greek.
