Configuring a VNS
      Setting up a VNS defines
         a binding between a default role specified for wireless users and an associated
            WLAN (Wireless Local Area Network) Service set, as shown in VNS Configuration Flow.
      There are conceptually
         hierarchical dependencies on the configuration elements of a VNS. However, the provisioning
         framework is flexible enough that you may select an existing dependent element or create
         one on the fly. Therefore, each element can be provisioned independently (WLAN services,
         Topologies, and Roles). For service activation, all the pieces will need to be in place, or
         defined during VNS configuration.
      You can use the VNS
         Creation Wizard to guide you through the necessary steps to create a virtual network
         service (and the necessary subcomponents during the process). The end result is a fully
         resolved set of elements and an active service.
      The recommended order of
         configuration events is:
         - Before you begin,
            draft out the type of services the system is expected to provide — wireless services,
            encryption types, infrastructure mapping (VLAN (Virtual LAN)s), and
            connectivity points (switch ports). Switch port VLAN configuration/trunks must match the
            controller's.
         - Set up basic
            controller services such as NTP, Routing, DNS, and RADIUS Servers, using one of the
            following methods:
               - Run the
                     Wizard, or
               - Manually
                  define the necessary infrastructure components such as RADIUS Servers. RADIUS
                  Servers are defined via the .
         - Define Topologies.
            Topologies represent the controller‘s points of network attachment. Therefore, VLANs and
            port assignments need to be coordinated with the corresponding switch ports.
         - Define Roles. Roles
            are typically bound to Topologies. Role application assigns user traffic to the
            corresponding network point of attachment.
               - Roles define
                  mobile user access rights by filtering.
               - Polices
                  reference the mobile user's traffic rate control profiles.
         - Define the WLAN
               Service.
               - Define SSID
                  and privacy settings for the wireless link.
               - Select the
                  set of APs and Radios on which the service is present.
               - Configure the
                  method of credential authentication for wireless users (None, Internal CP, External CP, Guest Portal, 802.1x[EAP]).
         - Create a VNS that binds the WLAN Service
            to the Role that will be used for default
            assignment upon user network attachment.
The VNS configuration page in turn
               allows for in-place creation of any dependencies it may require. For example:
               - Create a new
                  WLAN Service.
               - Create a new
                     Role.
                     - Create
                        a new Topology.
                     - Create
                        a new Class of Service.
