When the Location Engine is enabled and configured to publish locations, it posts location data in XML format to a given location. The location data is pushed to up to five given destinations periodically within the given time interval. Batch reporting continues until Location Batch Reporting is disabled, the Location Engine is disabled, or the controller is powered off.
In location-based applications and user traffic analytics, integrating partners often require more detail than simply the location of a MAC address. The client reporting option allows users to generate a report with details from the MU-Table.
The AP reporting option provides AP details that give a third-party App server context for the AP location.
To generate a report:
The IoT data is provided when the IoT port is enabled and provisioned. IoT is enabled by default for supported APs.Reporting Fields and Buttons
Field/Button | Description |
Report all station locations every (X) minutes | Select a time (in minutes) for station reporting from the drop-down list. |
Dimension Unit | Select a dimension unit, from the drop-down list, for measuring location destinations. (Displayed for Location Batch Reporting only.) |
Login | Login ID of the destination URL. |
Password | Password of the destination URL. |
Destination URL | List of destination URLs. |
Add | Click to create a new Destination URL. For more information, see Creating a New Destination URL. |
Delete Selected | Click to delete the selected Destination. |
Save | Click to save changes. |
