Before defining a specific VNS, define the global settings that apply to all VNS definitions. These global settings include:
The Global Default Policy specifies:
The controller ships from the factory with a default “Global Default Policy” that has the following settings:
The Global Default Policy is user-configurable. Changes to the Global Default Policy immediately effect all shadow roles created from it, just as if the administrator had made a comparable change directly to the incomplete role.
The global Egress Filtering Mode setting overrides the individual WLAN service Egress Filtering Mode setting.
The Sync Summary screen provides an overview of the synchronization status of paired controllers. The screen is divided into sections: Virtual Networks, WLAN services, Roles, and Topologies. Each section lists the name of the corresponding configuration object, its synchronization mode, and the status of last synchronization attempt. For more information, see Using the Sync Summary.
NAC Integration provides a list of NAC servers for use by the controller for passing DHCP (Dynamic Host Configuration Protocol) traffic. The NAC server can accept DHCP messages from the controller‘s DHCP server and use them to fingerprint devices. For more information, see Using NAC Integration.
This features configures how auto login behavior is handled for users with devices that need to authenticate to a captive portal to gain network access. For more information, see Using Client Login.
Topology Group Algorithms are used for selecting a member Topology from a Topology Group. The wireless controller will run one of the following algorithms: MAC based, Round Robin, Random Selected, and Lease used. For more information, see Using Topology Group Algorithm.
Use Netflow to forward packet information. Integration with ExtremeAnalytics no longer requires Netflow/MirrorN. See ExtremeAnalytics Support with Enhanced IPFIX Records for more information.
To display the Redirection URL option, enable Rule-based Redirection under Filtering Mode.
