Wi-Fi Protected Access (WPA v1 and WPA v2) privacy offers you the following key management options:
The client devices that run applications such as video streaming and VoIP require rapid reassociation during roaming. OKC helps such client devices by enabling them to rapidly reassociate with the APs. This avoids delays and gaps in transmission and thus helps in secure fast roaming (SFR).
The client devices should support OKC to use the OKC feature in the WLAN (Wireless Local Area Network).Note
The client devices should support pre-authentication to use the pre-authentication feature in the WLAN.
