The following table lists ExtremeWireless APs supported. AP models are listed in the order of most current models (top) to the oldest models (bottom), with the next-generation 39xx APs being the most recent product series.
ExtremeWireless APs
| AP Series | Product Number | Product Description | Product Long Description | XCloud Support |
| AP3916ic - 11ac Wave 2 AP with an integral security camera that lets you extend your Wireless LAN and provide simultaneous Wi-Fi service, BLE or 802.15.4 coverage and security. | 31034 | WS-AP3916ic-FCC |
Supports the IoT application. The integral ONVIF compatible security camera is connected to an internal wired Ethernet port, and the AP can be mounted on the ceiling or wall. Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). |
Yes |
| 31035 | WS-AP3916ic-ROW | Restricted Regulatory Domain: ROW (Available in regions other than U.S., Puerto Rico, and Colombia). | Yes | |
| AP3912 -Cloud-ready, Wall-plate, Dual band, Dual Radio 802.11ac/abgn, 2x2:2 MIMO Indoor Wave 2 access point that offers a range of connectivity options, including three policy controllable wired LAN ports (2.4/5G) and a wired pass-through port. and an integrated BTLE/802.15.4 radio for connectivity to Internet of Things (IoT) sensors and devices | 31025 | WS-AP3912i-FCC | Includes a four internal antenna array. Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). | Yes |
| 31026 | WS-AP3912i-ROW | Includes a four internal antenna array. Restricted Regulatory Domain: ROW (Available in regions other than U.S., Puerto Rico, and Colombia). | Yes | |
| AP3935 -Dual band, Dual Radio 802.11ac/abgn, 4x4:4 MIMO Indoor Wave 2 access points. | 31012 | WS-AP3935i-FCC | Includes an eight internal antenna array and active/active E/N data ports. Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). | Yes |
| 31013 | WS-AP3935i-ROW | Includes an eight internal antenna array and active/active E/N data ports. Restricted Regulatory Domain: ROW (Available in regions other than U.S., Puerto Rico, and Colombia). | Yes | |
| 31014 | WS-AP3935e-FCC | Includes eight, external, N-type jack connectors (4 connectors per band) for external antenna array and active/active E/N data ports. Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). | No | |
| 31015 | WS-AP3935e-ROW | Includes eight, external, N-type jack connectors (4 connectors per band) for external antenna array and active/active E/N data ports. Regulatory Domain: ROW (Available in regions other than U.S., Puerto Rico, and Colombia). | No | |
| 31020 | WS-AP3935i-IL | Includes an eight internal antenna array and active/active E/N data ports. Restricted Regulatory Domain: IL (Available in Isreal). | Yes | |
| AP3965 - Dual band, Dual Radio 802.11ac/abgn, 4x4:4 MIMO Outdoor Wave 2 access points. | 31016 | WS-AP3965i-FCC | Includes an eight internal antenna array and active/active E/N data ports. Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). | Yes |
| 31017 | WS-AP3965i-ROW | Includes an eight internal antenna array and active/active E/N data ports. Regulatory Domain: ROW (Available in regions other than the U.S., Puerto Rico, and Colombia). | Yes | |
| 31018 | WS-AP3965e-FCC | Includes eight, external, N-type jack connectors (4 connectors per band) for external antenna array and active/active E/N data ports. Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). | No | |
| 31019 | WS-AP3965e-ROW | Includes eight, external, N-type jack connectors (4 connectors per band) for external antenna array and active/active E/N data ports. Regulatory Domain: ROW (Available in regions other than the U.S., Puerto Rico, and Colombia). | No | |
| AP3805 - Dual band, Dual Radio 802.11ac/abgn, 2x2:2 MIMO Indoor Wave 1 access points. | 30912 | WS-AP3805i-FCC | Includes four internal antenna array. Restricted Regulatory Domain: FCC (Available in the U.S., Puerto Rico, and Colombia). | Yes |
| 30913 | WS-AP3805i-ROW | Includes four internal antenna array. Restricted Regulatory Domain: ROW (Available in regions other than U.S., Puerto Rico, and Colombia). | Yes | |
| WS-AP3805i | WS-AP3805i | Indoor AP with internal antenna assemblies. Supports the 802.11ac wireless standards. | No | |
| WS-AP3805e | WS-AP3805e | Indoor AP with external antenna connectors. Supports the 802.11ac wireless standards. | No | |
| WS-AP3805i | WS-AP3805i | Indoor AP with internal antenna assemblies. Supports the 802.11ac wireless standards. Mfg rev 5K or greater. | No | |
| WS-AP3805e | WS-AP3805e | Indoor AP with external antenna connectors. Supports the 802.11ac wireless standards. Mfg rev 5K or greater. | No | |
| AP3801 | WS-AP3801i | WS-AP3801i | Indoor AP with internal antenna assemblies. Supports the 802.11ac wireless standards. | No |
| WS-AP3801i | WS-AP3801i | Indoor AP with internal antenna assemblies. Supports the 802.11ac wireless standards. (Mfg rev 5F or greater). | No | |
| AP3825 | WS-AP3825i | WS-AP3825i | Indoor AP with internal antenna assemblies. Supports the 802.11ac and 802.11n wireless standards. | No |
| WS-AP3825e | WS-AP3825e | Indoor AP with external antenna connectors. Supports the 802.11ac and 802.11n wireless standards. | No | |
| WS-AP3825i | WS-AP3825i-1 | Indoor AP with internal antenna assemblies. Supports the 802.11ac and 802.11n wireless standards. App ID WS-3825i-1 (mfg rev 5L or greater). Units produced after May 2016. | No | |
| WS-AP3825e | WS-AP3825e-1 | Indoor AP with external antenna connectors. Supports the 802.11ac and 802.11n wireless standards. App ID WS-3825e-1 (mfg rev 5L or greater). Units produced after May 2016. | No | |
| AP3865 | WS-AP3865e | WS-AP3865e | Outdoor AP with external antenna assemblies. Supports the 802.11a, 802.11b, 802.11g, 802.11n, and 802.11ac protocols. | No |
| AP3705 | WS-AP3705i | WS-AP3705i | Indoor AP with internal antennas, 2x2x2 802.11abgn | No |
| AP3710 | WS-AP3710i | WS-AP3710i | Indoor AP with internal antennas, 3x3x3 802.11abgn | No |
| WS-AP3710e | WS-AP3710e | Indoor AP with external antennas, 3x3x3 802.11abgn | No | |
| AP3715 | WS-AP3715i | WS-AP3715i | Indoor AP with internal antennas, 3x3x3 802.11abgn | No |
| WS-AP3715e | WS-AP3715e | Indoor AP with external antennas, 3x3x3 802.11abgn | No | |
| AP3765 | WS-AP3765i | WS-AP3765i | Outdoor AP with internal antennas, 3x3x3 802.11ac, 802.11abgn | No |
| WS-AP3765e | WS-AP3765e | Outdoor AP with external antennas, 3x3x3 802.11ac, 802.11abgn | No | |
| AP3767 | WS-AP3767e | WS-AP3767e | Outdoor AP with external antennas, 3x3x3, 802.11n, 802.11a/b/g | No |
