Advanced WLAN Service Configuration Page
Field/Button | Description |
Timeout | |
Idle (pre) | Specify the amount of time in minutes that a Mobile user can have a session on the controller in pre-authenticated state during which no active traffic is passed. The session will be terminated if no active traffic is passed within this time. The default value is 5 minutes. |
Idle (post) | Specify the amount of time in minutes that a Mobile user can have a session on the controller in authenticated state during which no active traffic is passed. The session will be terminated if no active traffic is passed within this time. The default value is 30 minutes. |
Session | Specify the maximum number of minutes of service to be provided to the user before the termination of the session. |
RF - select one or more of the following options: | |
Suppress SSID | Select to prevent this SSID from appearing in the beacon message sent by the AP. The wireless device user seeking network access will not see this SSID as an available choice, and will need to specify it. |
Enable 11h support | Select to enable 11h support. By default this option is disabled. It is recommended that you enable this option. |
Apply power reduction to 11h clients | Select to enable the AP to use reduced power (as does the 11h
client). By default this option is disabled. It is recommended that you enable this
option. This option is available only if you enable 11h support. |
Process client IE requests | Select to enable the AP to accept IE requests sent by clients via Probe Request frames and responds by including the requested IE‘s in the corresponding Probe Response frames. By default this option is disabled. It is recommended that you enable this option. |
Energy Save Mode | Select to reduce the number of beacons the AP transmits on a BSSID when no client is associated with the BSSID. This reduces both the power consumption of the AP and the interference created by the AP when no client is associated. |
Radio Management (11k) support | Select to enable background scan. Optionally, enable Beacon Report and/or Quiet IE. |
Egress Filtering Mode | |
Enforce explicitly defined “Out” rules | Traffic is filtered as configured. For more information, see Configuring Egress Filtering Mode. |
Apply “In” rules to “out” direction traffic | The role of the source and destination addresses are reversed. For more information, see Configuring Egress Filtering Mode. |
Client Behavior | |
Block MU to MU traffic | Select the Block Mu to MU traffic checkbox if you want to prevent two devices associated with this SSID and registered as users of the controller, to be able to talk to each other. The blocking is enforced at the L2 (device) classification level. |
802.1D | |
8021D Base Port: xxx | The 802.1D Base Port number in the 802.1D area is the port number by which Extreme Management Center recognizes the SSID. It is read-only. |
Remote Service | |
Remoteable | Select the checkbox if you want to pair this service with a remote service. |
Inter-WLAN Service Roaming | |
Permit Inter-WLAN Service Roaming | Select to enable a client on a controller to maintain the
session, including the IP address and role assignment, while roaming between VNSs
having the same SSID and privacy settings. If not selected, when the client roams
among VNSs, the existing session terminates and a new session starts with the client
having to associated and authenticate again. The list of VNSs that share the same SSID and privacy settings displays below. |
Unauthenticated Behavior | |
Discard Unauthenticated Traffic | Select the checkbox to drop all traffic flowing to and from an unauthenticated station. |
Default Non-Authenticated Policy | Select the checkbox to apply the default non-authenticated policy to all traffic flowing to and from an unauthenticated station. |
Netflow | Click to Enable/Disable Netflow flag. For more information, see Using Netflow/MirrorN. |
Apply | Click to apply changes. |
Cancel | Click to close the Advanced dialog without saving changes. |
