Configuring Basic Captive Portal
Settings
When configuring
captive portal, different settings become available depending on the captive portal
option you choose.
To configure the
captive portal settings:
From the top menu, click
VNS.
In the left pane expand
the WLAN Services pane, then
click the WLAN (Wireless Local Area Network) Service. The WLAN Services configuration
page is displayed.
Click the Auth & Acct tab.
In the Authentication Mode drop-down
list, select a Captive Portal option.
- Disabled
- 802.1x
- Internal
- External
- Firewall Friendly External
- Guest Portal
You must configure a Guest
Portal before
Guest Portal appears
as a Captive Portal option. Only one WLAN Service can be configured for Guest Portal on a
VNS.
- Guest Splash
Click Configure.
The Captive Portal
configuration page displays. The page display differs depending on the mode that
you have selected:
