Configuring Common Configuration Default AP Settings
To configure common
configuration default AP settings:
From the top menu, click
AP.
In the left pane, click
The
Common Configuration tab is displayed.
Ports 1, 2, and
3, are available on the AP3912. Port 1 is the port that corresponds to the Camera
(CAM) function of the AP3916ic.
In the
Static Configuration section, you
can specify an EWC search list or use the search
list provided from the AP. Do one of the following:
Check
Learn EWC Search List from
AP to accept the AP's search list, or
clear the checkbox to specify a common search list for all APs. For more information
about creating
an EWC Search List, see
Static Configuration Properties.
In the
WLAN Assignments section, you can
associate a WLAN (Wireless Local Area Network) assignment to a radio.
- If the controller is in an availability pair, you
can apply default WLAN assignments to foreign APs, by selecting the Apply default WLAN assignments to foreign
APs checkbox. For more information, see Availability.
- To associate a WLAN Service in the list to a radio
and or a wired port, select the checkbox matching the radio and or port for the
selected WLAN.
- A WLAN service can be assigned to one or more radios
and ports. A client port can be assigned to only one WLAN service. The
assignment enables the port.
- Wireless and wired users associated to
the same WLAN service and receive identical service. They are affected
by the same policies and filters.
- AP3912 wired port assignments are limited to open WLAN services, MBA,
and captive portal.
- Click Save
Settings.
