Network Characteristics Tab
The hotspot Network Characteristics tab displays network parameters for the hotspot.
To configure Network Characteristics for the hotspot:
  1. Configure a WLAN (Wireless Local Area Network) Services Hotspot. For more information, see To Configure a New Hotspot.
  2. Select the Network Characteristics tab.
    Configuring Network Characteristics
    Graphics/Hotspot_Network_Char_Tab.png
  3. Configure the following parameters:
    IP Address Type Availability. The mobile device uses the IP Address Type Availability information to make network selection decisions. Select the level of restriction for each network type. Levels of restriction range from Public Address Available to Port Restricted and Double NATed Private Address Available.
    WLAN Metrics. Enter the values for maximum Uplink and Downlink speed and load parameters for the WLAN service.
    The mobile device uses information from the WAN Metrics configured here to make network selection decisions. The mobile device can determine if necessary throughput is available from the hotspot before connecting. If the mobile device receives indication that the basic service set (BSS) is at capacity, the device will not associate with that AP.
    Connection Capability. The mobile device uses connection capability information to make network selection decisions by determining which services are blocked or supported at the hotspot. Configure up to 16 ports.
    • To add a protocol, click the plus sign. Specify the protocol, the port number, and the status associated with the protocol. Valid Status values include: Closed, Open, or Unknown.
      Make an effort to configure all ports and do not rely on the Unknown value.
      Configuring Connection Capability
      Graphics/ConnectionCapability_dialog.png
    • To remove a port from the Connection Capability list, select the checkbox in the list row and click the minus sign.
      Removing a Connection Port
      Graphics/delete_connection_capability.png
    • To edit a port, click the list row. In the resulting dialog, modify the values and click OK.
  4. Click Save.
