Testing RADIUS Server Connections
To Test RADIUS Server Connections:
  1. From the top menu, click VNS.
  2. In the left pane expand the WLAN Services pane, then click the WLAN (Wireless Local Area Network) Service. The WLAN Services configuration page is displayed.
  3. Click the Auth & Acct tab.
  4. In the Server table, click the RADIUS server whose connection you want to test, and then click Test.
    Test RADIUS Server
    Graphics/TestRADIUSServer.jpg
    The RADIUS test is a test of connectivity to the RADIUS server, not of full RADIUS functionality. The controller‘s RADIUS connectivity test initiates an access-request, to which the RADIUS server will respond. If a response is received (either access-reject or access-accept), then the test is deemed to have succeeded. If a response is not received, then the test is deemed to have failed. In either case, the test ends at this point.
    If the WLAN Service Authentication mode is Internal or External Captive Portal, or if MAC-Based Authorization is selected, then this test can also test a user account configured on the RADIUS server. In these cases, if proper credentials are filled in for User ID and Password, an access-accept could be returned.
    If the WLAN Service Authentication mode is 802.1x, however, an Access-Reject is expected if the RADIUS server is accessible, and the test is considered a success.
  5. In the User ID box, type the user ID that you know can be authenticated.
  6. In the Password box, type the corresponding password. A password is not required for a AAA VNS.
  7. Click Test. The Test Result screen displays.
  8. Click Close after reviewing the test results.
  9. To save your changes, click Save.
