Wireless APs are added with default settings, which you can adjust and configure according to your network requirements. In addition, you can modify the properties and the settings for each radio on the AP.
You can also locate and select APs in specific registration states to modify their settings. For example, this feature is useful when approving pending APs when there are a large number of other APs that are already registered. On the Access Approval screen, click Pending to select all pending APs, then click Approve to approve all selected APs.
Configuring AP settings can include the following processes:
When configuring APs, you can choose to configure individual APs or simultaneously configure a group of APs. For more information, see AP Multi-Edit Properties .
Print
                        this page
Email this topic
Feedback
