Deleting a VNS
You can delete a VNS that is no longer necessary.
To delete a VNS:
From the top menu, click
VNS.
In the left pane expand the Virtual Networks pane, then select the VNS you want to rename.
On the Core tab, click the
Delete button. A pop-up window
prompts you to confirm you want to delete the VNS. Click OK.
Click Save. The VNS is deleted.
