By default, when a new VNS is created, the VNS is added to the system as an enabled VNS. A VNS can be enabled or disabled. Disabling a VNS provides the ability to temporarily stop wireless service on a VNS. The disabled VNS configuration remains in the database for future use.
The controller can support the following VNSs:
Platform | Active VNSs | Defined VNSs |
C5110 | 128 | 256 |
C5210 | 128 | 256 |
C4110 | 64 | 128 |
C25 | 16 | 32 |
C35 | 16 | 32 |
V2110 (Small) | 16 | 32 |
V2110 (Medium) | 64 | 128 |
V2110 (Large) | 128 | 256 |
To enable or disable a VNS:
