Enabling Management Traffic
If management traffic is enabled for a VNS, it overrides the built-in exception filters that prohibit traffic on the controller data interfaces. For more information, see Policy Rules.
To enable management traffic
for a topology:
From the top menu, click
either Controller or VNS. Then, in the left pane, select Topologies.
Select the desired physical or Routed topology. If the Layer 3 parameters are not displayed, check the Layer 3 checkbox.
Select the Management Traffic checkbox.
Click Save.
